steering componients
n00blike
CA
I bought a front suspension rebuild kit from PST a while ago. Most of the parts don't the little nub things that a grease gun would attach to, they just have a hole. Could i add those little nubs? would i just have to thread the holes and screw them in?
Also i plan on auto crossing it. I was thinking of going with all firmfeel stuff or MOOG. Is firmfeel that much better?
Also how do i tell between inner and out tie rods?
i think you are refering to tie rod ends. 2 tie rods left and right, and each has an inner and outer end.
the kit should have come with zerk fittings for grease.
well i have the tie rod ends with those fittings but the pitman arm and idle arm don't have the zerk fittings. I have seen others (diff company) that do. mine just have a hole.
