Stiff throttle in first gear after transgo install
340Duster247
Calgary
Hey guys recently installed a transgo 2. The install went very well and strait forward.
Finally got the car ready for first drive of the year and noticed when I put the trans into first gear the throttle pedal is extremely stiff. Less stiff in 2nd. And normal in drive.
Jacked it up and the kick down lever into the trans is extremely stiff to move in first by hand. (Cable detached).
Did I do something wrong :s.
I followed steps very carefully so I'm rather confused
so went back outside and now it's normal in first again. So took it for a little rip around block and was all good. Then slowly started to get stiffer again.
Sounds like your linkage rods are binding. Did you put one on the other side of the lever from before?
Sorry guys. Brain fart moment. Linkage. Ughhh that's embarrassing. Amateur hour hahaha
New set up is looking nasty tho lol
