And ? is it nos, is it for sale:happy7:
What cam did you end up putting in the 340?? I believe the Commando 273 which was replaced by the 340 had a 270-280 advertised duration. with a lift of .420/.443 at 112 degree lobe center. And the 340 had 268-276 advertised duration. With a lift of .429/.444 at 114 degree lobe center. Any hoo! Here is a stock replacement part # for 68-73 340 4 BBL replacement camshaft. M77-229-1654. It is also referenced as 71-74 360.
Here is my 69 340 Dart with a stock cam, I think it sounds great for a stock cam and exhaust..
‪1969 Dodge Dart 340 Bahama Yellow/Butterscotch‬‏ - YouTube
I couldn't find spec's on the part #:banghead:
Also the 273 had a single plain intake and adjustable solid lifters which made for really good top end where as the 340 had a 360 degree intake with hydraulic lifters which made for really good low end. I had a 70 Dodge Dart Swinger 340 edition with the AVS Spread Bore set up that was bone stock except for Headman Headers. It had a 150 speedo in it, thus rally dash and at low altitude it topped out at 135 MPH with the timing set 1 degree after top dead center. That car had to be set like that to avoid ping & detonation because of high compression. 92 octane Union 76 gas back then was the best mixed with Texaco unless you could buy Trick racing fuel. Both the 273 Commando & 340 were high compression engines:burnout:
The AVS is not a square bore carburetor.
