360s never came with steel cranks right? I wonder the strength difference in let's say, a 273 crank. The journals are smaller, so is its stroke, but its also steel.
Steel? Yes, type of steel or better yet, how it was made is a different story.
Cast or forged. Crank and rod opinions below.
A well machined etc.. Like Moper said, set up, cast crank, will be just fine under 500 HP & Tq. While you could actually exceed this a bit, the parts involved start falling under a lot of stress. IMO, while it could be a great bracket engine for a time, I would not recommend such a power level for every day usage and abuse.
Even if it were only used on weekends, and or in addition to once or twice a week to shows etc... The high out put engines aren't the most happiest thing to drive and live long under "Calm" conditions. At that 500 HP level, even a slow cruise is a high stress ordeal for the engine.
It may live a long time, but, IMO, it's the whole combo of things that would have me shy away from such builds and heavy abusive usage's like that slow cruise and then drag race the street back to a slow cruise for a burger, etc....
IMO, if your gonna step up to the plate for some getting serious on HP level power output's, do like wise on parts.
