Strawberry smoothie for dessert. Not boozy enough...
Our....BOOBS!!!Big *** burger... Burning wood... Bourbon.. Bed seems the next logical 'B'.
If you have burning wood...you might need to see a doctor!Big *** burger... Burning wood... Bourbon.. Bed seems the next logical 'B'.
See how much a rental fork lift would be, trust me, I loved having one when we put ours up. Made for a very easy install.Finally unboxed my lift, got everything off the dolly but the ramps- too heavy. I will have to rig a strap and use engine hoist. Will be reading through the manual tonight, can't believe I am just getting to this.
NiceI know how much the one was that I got it into the shop with (pictured) but that was a 4WD. I will keep that in mind, have seen videos and it seems like the biggest mistakes are swapping sides/parts and having to tear it back down. I thought I was opening a manual tonight, turns out it's all ANSI standards stuff, lifting guides etc. I have an electronic and a printed PDF installation manual, need to look through that and get going. Electrician set aside a 220 circuit for it in the panel but hasn't ran the wires through the conduit yet as he wants to look at load requirement and location of the motor/electrical connection on the lift.
Nice
2 post. Atlas 10k commercial truckJust curious 2 post or 4 post?
If I were to do it again, I’m going 4 post.When I see suspension work going on I second guess the 4 post. I did get a jack kit, hopefully it works well, never used one on a lift.
There is only one thing i have not been able to do with my 4 post,lift a body off. I did lift a box off a pickup easily though.When I see suspension work going on I second guess the 4 post. I did get a jack kit, hopefully it works well, never used one on a lift.
Im still rolling.So this Penguin is driving his car, and all of a sudden it stops moving. He looks across the street and sees a Transmission shop. He just coasts in, and tells the mechanic what happened. " Give me a few minutes and I can give you a diagnosis". Great. So the Penguin is waiting and sees an ice cream shop next door, and decides to get a cone. It is tough for penguins to eat ice cream and he makes a mess of it. Well, in about 30 minutes the penguin comes back to shop, with some vanilla on his shirt, where he is told, " Looks like you blew a seal". The penguin promptly reply's, "No, it is just ice cream.!!!![]()
Guess i havent shared it for a while, thats my blown seal go-to.I think I worked with that crowd![]()
Then there is flat out hurling insults..
