You edit fastHuh?
You edit fastHuh?
So you know what STP stands for???
Um Tim, don’t drink bong water before typing lol
What's bing water..... do you order it online?
Don’t know, haven’t tried it but seeing how it says will blend with motor oils on the bottle, I don’t see why notCan the STP and Motor Honey stick to the Lucas assy lube??? If not I would run the STP/Motor Honey instead of the Lucas....
I already put the Lucas on the mains. But yeah, it’s tacky, not quite as tacky as STP, but more than motor honey.I would then use the STP or motor honey first, then the Lucas on top of that...
If the base doesn't stick as well as the top, it may 'wash off' easier....
Try putting the Lucas on your hands, then the STP or motor honey on top and wash your hands and see how easy/hard it is to wash off...
Hmmm I’ll take it all back apart I suppose and do it that way. I trust you all more than a book at the momentWhat I said was, was told to only use engine oil, except for cam shaft. Can lead to false torque readings....can form a hydraulic lock, preventing full torque......This is what I was told.....
I think some of his thinking was the thick STP could block oil holes. Starving bearings for critical engine oil at start up.....I think any excess oil or STP would squish out the sides before becoming an issue....
If the STP or oil gets trapped and can't escape, then it may hydraulic lock...
I've always torqued my mains and rods after installing the Motor Honey and not had a problem, even if I had excess on the rod and cap mating surfaces...
If you trap liquid in the sealed cylinder, it will hydraulic lock... But if you take the spark plug out, it will get pushed out the spark plug hole.... If it has an escape route, it will not hydraulic lock...
Oh that’s one thing I wanted to mention. Managed to some how get the cam bearings perfectly lined up hole wise, even the tricky one number 4 I think it is, the one with 3 holes. I took my bore camera down each passage way to confirm after I ran brushes thru them.I think some of his thinking was the thick STP could block oil holes. Starving bearings for critical engine oil at start up.....
They brand new ARP studs.I wouldn't take it apart, you will stretch the bolts a little more when you retorque them... If you already have assembly lube on there, keep it and it will be ok... Not worth stretching main bolts more... Save that clamp cycle for another time....
We used regular engine oil to assemble the crank and rods at the engine factory, but also had a cold test stand that filled the oil, primed the oil system, and would give us a signature pattern for oil flow where you could see the 'bumps' for when the squirt holes in the rods were squirting in less than two hours after we installed the crank and pistons... They could catch a plugged oil squirt hole in a rod with that test....
I have built/assembled dozens and never had issue using just engine oil........BUT lots of ways to do the same thing....I doubt it... The engine oil is compatible with the motor honey and will 'dilute'/mix with it when they meet... I don't think the STP is thick enough to block an oil passage, especially when you are pushing 50 lbs of oil pressure at it...
I read this thinking of Boomhauers voice in my head.Fn assface . Keylogger. i did a safari search for floor pan for my dart. What pops up right away on assface marketplace? You got it. Effers.
Most important is priming with drill.......I have built/assembled dozens and never had issue using just engine oil........BUT lots of ways to do the same thing....
