You have to leave something to the imagination!Yes, no encouragement! The boss was saying he needs to strip and get photos of his parts.....
That'll warm you up better than the coffee. But still need coffee
Well, polish for sure. We do have anodized aluminum parts here at work. I would think it would work. What case?OK heres a new one. Can you polish and anodize a aluminum case?
You want to polish and anodize a 318 ?????? Thats Aluminum ?????Just a 318, Guess to match a paint scheme?
You want to polish and anodize a 318 ?????? Thats Aluminum ?????![]()
To be fair....I was confused also....Not me a Dist for a guy. Dont you read back?![]()
Heres what you said Way.......KKKKKKKKKKOK heres a new one. Can you polish and anodize a aluminum case?
Dad had a Pertronix distributor in it. What do you recommend? If/when going to boost, it will be dialed back and locked out.Eric what ignition are you going to run?
Locked out is easy. Crank trigger? Look at the petronixs 510 setup. I am, impressed with it.Dad had a Pertronix distributor in it. What do you recommend? If/when going to boost, it will be dialed back and locked out.
So that's what that compartment in the back of a shopping cart is for. Makes sense now why it has a plastic flap to prevent chafing. Thanks Man!For those that prefer Tea...
this?Locked out is easy. Crank trigger? Look at the petronixs 510 setup. I am, impressed with it.
Yes. If needed I have some NOS ones in a kit with the coil. I think it blows the MSD away and no pills needed either. Go into the installation instructions break down the features.
yeah, i love that it uses dial switches... pills are just more money and 100% getting lostYes. If needed I have some NOS ones in a kjut with the coil. I think it blows the MSD away and no pills needed either. Go into the installation instructions break down the features.
