Stop in for a cup of coffee
If you can tack weld the riv nut, i highly reccomend it. I have had one or a few that spin for some reason,even though i crimped them tight.
Yep the early Jeep JK models used rivot nuts to anchor the soft tops. Needless to say, that didn’t last long.
I just turned the furnace on. I need to buy heating oil but waiting for the price to go down. I wonder if it will by next fall
He's pulling it this weekend. He said the weather has been garbage. Waiting to hear back from him
Didn't you already go through trans issues? and please keep the pushbutton... same issues would have happened with a non pushbutton :) BTW.. when i put my trans in i have the pan just on with 2 bolts and no gasket so i can make sure the shifter is adjusted perfect.. then do the pan
