dodgefreak73
Help!!!! :banghead:I don't know if this topic has been touched on before but I need to know that I'm not going crazy. First off my car is a '73 Dart with a 318ci and power disc brakes everything is factory nothing converted or modified. The problem I'm having is the front brakes are not releasing right away, this doesn't happen every time and seems to be worse when turning. This problem has always been there since I got the car 4 yrs ago but has gotten worse. It has always had very touchy brakes (over assisted) and will plant you against the windshield if you hit them too quick. I had it out for a run the other day and it was the worst it's been yet. I was slowing for a turn let off the brakes and started to turn the corner and the car kept slowing down, this was not a stop and turn it was a rolling turn the car almost came to a stop before it let go. What I've done to attempt to rectify this problem so far is new master cylinder, both calipers and both flex hoses so far nothing has changed. I don't want the car to sit all summer but I will not drive it any more the way it is as I'm afraid of getting rear ended as the brake lights go out but the car keeps slowing. Sorry for the long post but I wanted to get as much info in as possible. Can anyone shed some light on this? Thanks in advance.
dodgefreak73:banghead:
