Thats pretty sensible.Sorta
If you're holding back the gears, for cruising, consider this;At sub 2000rpm,I dont think the intake vacuum has yet peaked.Unless your cam has been advanced a good bit.I cant say this with absolute authority because I've never had a stroker. However my 366 with a 292/509 cam, had not yet peaked. It wanted to cruise at 2400 or better.
The 3.55s, and .69o/d,(3.55x.69=2.45)put your cruise rpms into the basement(65mph= less than 2000). That cam wants to cruise 10% to 15% higher, to start getting an efficient cruise burn.Ima guessing 2200rpm at the least, 2400 would be better.
3.91s would put you at 65=2180 w 27" tires.This gear puts you at 5350/110mph.
4.10s would put you at 2285@65, and 110=5620, now you're getting somewhere. Of course by now you'd be up several mph. Say,115=5860 with the 4.1s, and you'll be in the 11sies.
So for me,the 4.10s would be the minimum. Your QTr would pick up considerably. If you tune your timing, and especially your Vacuum advance, you're likely to pick up a couple of mpgs too. Your plugs will last longer. Your oil will/may stay cleaner. And your engine may cruise cooler.
Oh yeah....She'll be a serious brawler.SERIOUS.
Aw heck, maybe my whole thinking here is out to lunch...............I forgot you were EFI'd
I've never had EFI either.So if you're injecting pretty late at cruise, I suspect you might just be able to get away with those 3.55s.
Yeah so ignore me. Im stuck in carburetor land.
