I have seen photos of after-market adjustable strut arms. I think those allow you to adjust your caster more, which helps with radial tires. Don't know the price. When you re-assemble, use the "improved design" strut bushings. Don't mess with the 1-piece "can't squish rubber thru hole", "frame cuts rubber" original design, even if they are real cheap.
