I have had the same problem. Go under the car and unhook the shifting rod and see if you can shift the tranny out of first by hand. you may have bent a shift rod and put it a little out of adjustment, or the shifter is junk like mine. If you bent a shift rod it doesn't do any good to straiten it, just go out and buy the good Hurst Competition Plus shifter and rods and it will be fixed for good. My shifter hangs up sometimes and doesn't let it shift at all. Hope this helps. Been watching your posts and seen you have been racing it a bit. Your car reminds me of mine I think they run alot alike. Thanks Rick
