Stuck two barrel carb difference?
69moredoor
VA
Was rebuilding a spare carb when I notice something I had not noticed before. What’s the marked bump out?
????WTF??? Different bolt pattern? I don't get what you are asking
On the second carb..there is a bump out with a hole in it. What’s the purpose of the bump out/hole. The other two barrels I have do not have that. The arrow points to the bump out/hole that the one on the left does not have
Part of the vent I'd say. This what you are talking about?
Is it part of a gasket? Might be a 'universal' gasket, fits a few models.
Irr tree s not part of a gasket. It’s part of the center body of the carb. I’ll take a better pic
May be where something was attached, like a choke cable hold-down bracket? It does look like a manual choke carb. Just a wild guess.
It could very well be simply a locating point for the machining process
