1. Ironmike
    Ironmike Well-Known Member
    1,419
    232
    Oct 11, 2009
    Western Pa
    Local Time:
    4:54 PM
    Decided today to strip this pair of Edelbrock heads that fell into my lap. They're going to Hughes for the full work up.
    So I get all the springs off and can't get even 1 valve out of the head. Guides feel pretty tight and they just won't get past the top of the lock groove on the valve. Didn't want to destroy the valves, as someone else may be able to use them. Anyone have a good idea how in hell to get them out?
    Guy who had them first bought them from Eddy ready to run. Told me he bolted em on and that was that. Guess this is a case of the notorious tight guides we've all heard about. Some are obviously way to tight.
    • Thanks! Thanks! x 1
    • yellow rose
      yellow rose Overnight Sensation FABO Gold Member
      28,537
      24972
      Jun 19, 2015
      Central Washington
      Local Time:
      1:54 PM
      You have to file the grooves. The locks have beat the groove up and now it won't go past the guide. Just run a fine file around the top of valve til they slide out.
    • j par
      j par Well-hung Member
      27,884
      15312
      Jul 2, 2014
      Portland Oregon
      Local Time:
      1:54 PM
      GET A BIGGER HAMMER ! !!! :mob:
      and remember to use a self-leveling reciprocating spreader....:thumbsup:
      I want edelbrock heads to fall into (or next to) my lap!!!
    • AJ/FormS
      AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
      20,987
      8308
      Jan 19, 2014
      South-Central Manitoba,Canada, 900ftelevation
      Local Time:
      3:54 PM
      Send 'em to me; I know what to do with them.
      But yeah file them, just the area at the valve lock grooves, and only taking off the sharp edges. If the valve will not spin, this is very difficult, so perhaps a few applications of Deep-Creep penetrating oil.This will prevent the guides from being grooved. After that, a brass pin punch and a hammer. Don't forget to make room under the valve for it to drop out, onto the bench.
    • Ironmike
      1,419
      232
      Oct 11, 2009
      Western Pa
      Local Time:
      4:54 PM
      Guess I'll file em. Wanted to preserve them and give em to someone who might be on a budget. Maan those guides are really tight. Can't believe some people just "bolt em on".
    • yellow rose
      28,537
      24972
      Jun 19, 2015
      Central Washington
      Local Time:
      1:54 PM
      Do they feel that tight before they get to the groove? May just be the stem it bitched up at the groove. Using a fine file won't make the unusable. Now if you get after them with a grinder.....
    • MOPAROFFICIAL
      MOPAROFFICIAL Well-Known Member
      7,943
      7145
      Jun 1, 2016
      Beach
      Local Time:
      1:54 PM
      The valves are fine, file them and re use or sell or kick them to your friend.
      Such basic tear down procedure...:welcome:
    • Ironmike
      1,419
      232
      Oct 11, 2009
      Western Pa
      Local Time:
      4:54 PM
      Some are absolutely too damn tight. Yeah, he ran it 800 miles or so, but you can feel some drag. I'm sure a head shop would have reamed them some, had they been checked. No matter now......
      Well, hopefully I'll be able to save them for someone.
    • Ironmike
      1,419
      232
      Oct 11, 2009
      Western Pa
      Local Time:
      4:54 PM
      I confess I haven't torn down many heads. My own have never needed tearing down. That's why these are going to Hughes. I don't have a CNC machine or a flow bench. Once they're back in my hands, won't ever need to tear them down.
    • MOPAROFFICIAL
      7,943
      7145
      Jun 1, 2016
      Beach
      Local Time:
      1:54 PM
      Ever is like never, you never say it.:steering:
    • Ironmike
      1,419
      232
      Oct 11, 2009
      Western Pa
      Local Time:
      4:54 PM
      Yeah, I know what ya mean. Shoulda said HOPEFULLY never. Really, other than changing seals or a known spring.....head work has always been a "dark science" to me. Installed height, coil bind, open pressure........all those new tools I'd have to buy.
    • SIX225
      SIX225 Well-Known Member
      144
      71
      Jan 31, 2016
      Illinois
      Local Time:
      3:54 PM
      Haven't done it on a valve, but I've used a sharpening stone on shafts with couplings to remove burrs from set screws. Works better than a file.
    • yellow rose
      28,537
      24972
      Jun 19, 2015
      Central Washington
      Local Time:
      1:54 PM
      I'm sure they are too tight. But the not coming out is from a burr. If they were stuck from being so tight you can't get them out, they'd be bent. And they might be.
      And the guy who said use a stone is correct. The fine stone is better but I ASSumed everyone has a file of some kind. Not everyone has stones laying around.
    • moper
      moper FABO Gold Member FABO Gold Member
      15,929
      2051
      Dec 27, 2004
      eastern CT
      Local Time:
      9:54 PM
      I use a small, very fine file all the time on valves taht hang up from the grooves being beaten. No big deal.
    • Ironmike
      1,419
      232
      Oct 11, 2009
      Western Pa
      Local Time:
      4:54 PM
      used a real fine stone I use for filing sears on 1911 handguns. Worked perfect. Like you all said, I just stoned off the little burr.
    • yellow rose
      28,537
      24972
      Jun 19, 2015
      Central Washington
      Local Time:
      1:54 PM
      How many showed signs of sticking.
      BTW, retarded timing will stick exhaust valves in a NY second.
    • Ironmike
      1,419
      232
      Oct 11, 2009
      Western Pa
      Local Time:
      4:54 PM
      Every exhaust and 4 intakes.
    • yellow rose
      28,537
      24972
      Jun 19, 2015
      Central Washington
      Local Time:
      1:54 PM
      Holy crap. Doubt that is tune up related.
      When you buy assembled heads they have to be checked. I know you know that, but many think you can bolt that crap on and go.
    • T-N-T
      T-N-T WMMC Member
      371
      108
      Oct 3, 2015
      WI
      Local Time:
      3:54 PM
      Is any head really ready to run out of the box? Even if the box has been opened?
      I have a pair of heads I bought from Hughes that they setup. They weren't been cleaned after the valves seats were cut by them, they had casting flash in two intake ports that easily snapped off with one finger and the bronze guide inserts they installed that felt like they had gravel in them. The exhaust valves all sit .020-.035" lower then the intake valves do too. Needless to say I was less then impressed and glad I didn't just run them.
      The Eddy heads I returned had so much core shift that some exhaust ports that the gasket and header overhang the rear edge of the ports. I never bothered pulling those apart but I probably would have found sticky valves too. The valve height was within .010" though.
      I probably would have had better luck with Speedmaster heads.... I'm still not sure which heads I'm going to run.
    • Ironmike
      1,419
      232
      Oct 11, 2009
      Western Pa
      Local Time:
      4:54 PM
      I didn't buy em. They were....given to me after a guy ran them 800 miles or so. right place, right time. My only expense will be Hughes full CNC, some springs that will handle a .680 or so roller and the standard items.
      • Like Like x 1
      • T-N-T
        T-N-T WMMC Member
        371
        108
        Oct 3, 2015
        WI
        Local Time:
        3:54 PM
        Now that I could deal with. Definite right time and place. I think I would still pull them apart after they were done though. I'd probably have the pushrod tubes plugged and then CNC ported into bigmouths. Hughes Engines
      • Ironmike
        1,419
        232
        Oct 11, 2009
        Western Pa
        Local Time:
        4:54 PM
        Thought about the big mouth deal. I'm only planning for the 600 HP plateau. I think their full CNC program, if they do it like they say, will get me there.
        Now if I had an R3, and was planning on a lot of track time........HELLO Big mouth!
