1. DECIPHER
    DECIPHER Well-Known Member
    244
    28
    Jul 27, 2015
    Denver
    Local Time:
    10:27 AM
    Taking he dash out to paint my needles and clean the cluster I bumper the ammeter positive wire and blew something where would this fuze be? Thanks
  2. straightlinespeed
    straightlinespeed Sometimes I pretend to be normal Staff Member FABO Gold Member
    10,204
    3608
    Oct 21, 2012
    Oakdale, MN
    Local Time:
    11:27 AM
    Fuses are located under your dash, by your drivers side vent. However I would look at the fusable link. Which is located in your engine bay, near the bulk head connector.
  3. GEO
    GEO Sarcasm Inc.
    1,927
    230
    Feb 12, 2012
    Irvington ,Indiana
    Local Time:
    11:27 AM
    Would have been a lot easier to unhook the battery before you messed with the dash
  4. TrailBeast
    TrailBeast AKA Mopars4us on Youtube
    21,329
    8844
    Mar 11, 2011
    Arizona
    Local Time:
    9:27 AM
    That is going to be the fusible link that you blew under the hood most likely.
    Ask me how I know. :D
    Look for it coming right out of the bulkhead connector.
  5. 67Dart273
    67Dart273 FABO Gold Member FABO Gold Member
    42,930
    10499
    Oct 14, 2010
    Idaho
    Local Time:
    9:27 AM
  6. DECIPHER
    244
    28
    Jul 27, 2015
    Denver
    Local Time:
    10:27 AM
    I had the ammeter and dash disconnected already I knew better but thought I knew better....
  7. DECIPHER
    244
    28
    Jul 27, 2015
    Denver
    Local Time:
    10:27 AM
    [​IMG]
  8. MrJLR
    MrJLR Built, not bought FABO Gold Member
    5,206
    5321
    May 14, 2015
    Chino, California
    Local Time:
    9:27 AM
    I always disconnect the battery when i do stuff like that....!!!!
  9. TrailBeast
    21,329
    8844
    Mar 11, 2011
    Arizona
    Local Time:
    9:27 AM
    I always have a self resetting circuit breaker instead of something that has to burn up under the hood when it works as designed. :D
    It automatically resets in about 3 seconds.
    I do still disconnect the battery though, and we have all done something we knew better and did it anyway.
    Lord knows I have many a time.
  10. DECIPHER
    244
    28
    Jul 27, 2015
    Denver
    Local Time:
    10:27 AM
    All is alive didn't even blow the inline fuze I have to get under the car soon I pulled the speedo cable to lube and it won't go back all the way, ehh I also need to adjust the shift gate on the auto so it lines up anyway
  11. TrailBeast
    21,329
    8844
    Mar 11, 2011
    Arizona
    Local Time:
    9:27 AM
    So you're going to make us ask what it was? :D
  12. KitCarlson
    KitCarlson Well-Known Member
    2,511
    398
    Jan 17, 2008
    Middle Tennessee
    Local Time:
    11:27 AM
    The service manual has good info on the shift gate and kick down rod adjustments. Both are easy to follow.
    http://www.mymopar.com/index.php?pid=109
  13. DECIPHER
    244
    28
    Jul 27, 2015
    Denver
    Local Time:
    10:27 AM
    Gremlin? Dunno cleaned everything checked link was ok put it all back and started up
  14. RedFish
    RedFish Well-Known Member
    24,175
    2791
    Sep 5, 2007
    Local Time:
    11:27 AM
    The link itself cant heal. The OEM fusible link had a service disconnect. If you did have a brief open circuit condition, in that or the bulkhead terminals would be my guess. Something you cleaned or wiggled while cleaning was the fault.
    Speedo cable and sheathe makes 90 degree turn under the drivers seat area. That's where the cable tip normally hangs, refuses to push through that turn. Jack the car up, go under and disconnect from trans or... Reach under and remove sheathe from under a sheet metal strap and wiggle it around a bit has worked for me.
