jhdeval
Please laugh because it is funny if not unfortunate. So 65 Barracuda my speedometer cable broke inside the housing and appears to have fused to the housing that goes into the transmission. So in an attempt to save over 100 dollars I decided I couldn't hurt anything anymore then it is and I decided to try and drill out the cable. It seems to have worked sort of the end is certainly open again but the rest of the cable is not coming through. So here is my thought the large end that goes into the transmission I am pretty sure is where the issue lies. Can I carefully cut the end off without going through the core and "clean out the end" then reattach it? It seems the housing past the large end is really just that a housing so I figure as long as I make it waterproof maybe like silicon tape or something it would be safe. Any thoughts from the more experienced?
My other thought is ATP sells speedo cables and they have the wrong part listed for the Barracuda but if anyone knows the right part Rockauto has them pretty cheap and I will just order the right cable and housing then,
