Subframe connectors
Mopar70Dart
Mopar Kid
Annapolis Md
Hey guys with 70 darts can I see your subframe connector installations? Just curious on how they look underneath and how to go about getting around the emergency brake cable.
I just asked a questions about subframe connectors over a moparts...
check out the thread...
http://board.moparts.org/ubbthreads...nGottaDemonDad&topic=&Search=true#Post4530373
I do not have an answer to the emergency brake issue. I cut my connectors last weekend and when I was trying to install it the subframe connector cover the whole for the emergency brake hole completely.
I did not weld on waiting for options.
Craig
Thanks for the clarification. I have the car on floor jacks right now. I will get a new bit and grill that hole prior to welding in the subframe connectors.
Thanks,
Craig
IIRC, there will be two different size holes. Larger in the front. There is a small sleeve/cup that goes on the cable cover to keep it from pulling through the x-member.
