mopar3401987
i was looking at some paxton superchargers for my 340 and was wondering if it will handle 7-8lbs of boost
my 340 current set up
fresh rebuild
.30 over
eagle stock stroke crank (cast)
out of the box closed chambered eddy heads 60779
eddy air gap intake
1 inch hvh spacer
750 prform carb ( will change if i go with a paxton super charger)
cam is a Hughes SMC2336AL Intake Valve Lift Intake .512" Exhaust Valve .518 Intake Duration at .050"223° Exhaust Duration at .050" 236° ( will change if i decide to go with the super charger)
2500 rpm stall
10 to 1 compression
gears posi 3.91
full length headman headers
ignition accel distributor with a REV-N-NATOR box rev limitor set at 5500 rpm
fuel pump is a Edelbrock Performer RPM Street Fuel Pumps 1720 110 gph
Maximum Pressure (psi):6 psi
http://www.jegs.com/i/Paxton/769/12...Lk_RoqtPXYNS1QBTFY0nK6-obaQAQRPtrUaAtsQ8P8HAQ
fresh rebuild
.30 over
eddy air gap intake
1 inch hvh spacer
2500 rpm stall
10 to 1 compression
gears posi 3.91
