super thermoquad choke issues
And you have the choke wired to a start/run wire?
Adjust the chokes housing to move the embossed hash mark to the second line forwards, towards the front of the car and tighten down. This should have the inside tang hook the cool within providing tention to close the choke butterfly.
On the drivers side of the carb there is a fast idle screw that needs to be adjust to hold the throttle arm open on the second step of the fast idle linkage.
thanks i'll look at it tommrow
TQ choke: Choke plate snaps shut under spring pressure, props open fast idle cam... done deal. Whats it not doing?...
One tip most people are not aware of. The Thermoquad's choke thermostat operate's backwards from any of the rest. However, the AFB and AVS and possibly even the Holley choke thermostats will interchange. If it does not have the correct choke thermostat, it will tighten up more as it heats up, closing the choke harder, rather than opening it.
thanks
