SUPERCHARGER = OIL LEAK
WAYNE0
milton pa.
I installed the paxton supercharger and put some miles on it now i have major oil leak. It looks like its coming from the rear main seal. Ill tell ya one thing i am not pulling the engine to change that seal. If this is what it is going to be like with this thing the supercharger will find a new home. I even installed extra breathers on the valve covers.
I thought the same thing, but it was the oil sender behind the intake. It didn't look like it was leaking.
You can change the rear main without pulling the engine (small block). Haven't done it myself, but looks doable after watching a few videos.
lolo that would be a easier fix ill have to look a little closer this weekend yes small block 397 ci 360
