I adjusted the timing, although the car seemed to run better at almost 15 degrees initial timing, which according to your thread sounds a little high? Since I didn't build the engine, I am not sure if it has a cam or not. I did plug the vacuum line when timing it, but that sounds like quite a bit of initial timing. No detonations, and seemed like it wanted more. Any thoughts?
Engines always idle better with more initial, sometimes up to 30 degrees.
But in your case, you can't give it that much Idle-Timing. Because;
1) the starter probably won't crank it, and
2) anytime you change the IdleTiming, ALL other timing points also change, and
3) your PowerTiming could be high enough to rattle your piston skirts straight into the oilpan. and
4) extra timing will often band-aid a carburetion issue. Fix the carb, and you can back off the timing.
5) stale fuel will cause all kinds of strange manifestations under anything but steady-state operation. I rate freshness by 5 colors
1) Clear is Fresh .
2) Yellow is still usable; works Ok in your Injected DD, but a carbed car is in distress; some of the Vocs have evaporated, and she won't like transitioning
3) between Yellow and Orange, is not good for a carby; most of the VOCs have evaporated and so she will be hard to start, hard to keep running until warmed up, and she hates to transition from idling to anything else.
4) Orange is best left to your push-mower..... if it will start. All of the Vocs have evaporated, and the mower will need a carb adjustment but, with a sharp blade you can still mow.
5) Red is useless, go ahead spill some on a concrete floor and try to light it. If you can even get it to burn, it will smoke and sputter and leave an ugly greasy mess on the floor.
15* of Idle-Timing for your 360 is not too much, but also not required, and you will have to limit your Power-Timing back to about 34* by around 3200 rpm. If your 360 wants that much, she probably has a fueling issue.
The thing is, with that much timing, the throttle will be nearly closed with a stock/stockish cam, and the transfers will be slow to come alive on throttle tip-in, leaving you with the hesitation you mentioned.
A bog is a different deal, this can happen when the throttle is slammed open at a much faster rate than the tip-in. And this is almost always an accelerator pump issue, usually pump-timing. On most carbs the pump has to be readjusted after any major curb-idle adjustment.
