moparduster
Does someone have a like to a how to remove and install lca and torsion bar on a 71 duster?
no fancy tools needed!![]()
If you're taking out the LCA you don't need a torsion bar tool. Once you've unloaded the adjusters and pulled the retaining clips just take the nut off of the LCA pivot and use a dead-blow hammer on the LCA. The LCA will slide back out of the K member, and the torsion bar will slide out of the back of the socket. Once the LCA is clear of the K member, a couple more strikes with the dead blow hammer in the other direction should knock it off of the end of the torsion bar. Just resist the urge to use a sledge hammer instead of a dead blow hammer and you should be free and clear with no damage to the torsion bars or the LCA's.
Eliminates the chance of marring the torsion bars, and no fancy tools needed!![]()
i agree, ive never used a torsion bar tool for any front ends ive ever rebuilt
