And before anyone pokes me with a stick, I did use the search function. Just didn't find what I was looking for.
Anyway, 74 Dart Sport currently power brakes, disc front drum rear. I want to switch to manual. I already have the correct pushrod, I have been told I can use the current master cylinder. In fact I have read the the manual cylinder would have been better with power assist and vice versa.
So what else do I need?
What do I need to do besides remove the booster and plug the port in the intake?
Does the MC bolt up to the booster bracket, firewall????
I know I will need to adjust the brake lines (that's a given).
What about the proportioning valve, same or do I need one for manual??
Thanks in advance for any insightful info!!!
