Sway bar wanted
1969GTS
Rating - 0%
0   0   0
I'm in need of a complete sway bar with end links and all. I assume the guy who raced my project in the early 90's tossed it or lost it. I'm looking for the old style for a 69 Dart.
Thanks
Dave
Your car probably never had the sway bar. Only certain models got them.
Easy way to tell... Lower arms have swaybar attach brackets welded on ? I still need those. There is a set on ebay priced at 250.00 . Complete hellwig kit can be had for that and the Addco for even less.
The early under K member sway bars were subject to breaking the forward bushing mounts anyway. Good luck :)
Good to know. I thought they all came with them. I have no brackets welded on but have the ams with the holes in them when it got a disc brake conversion. I don't plan on rally racing anyway. Its going to be a street and strip car. I may not even need one. I understand most drag racers take them off anyway.
Oh a bar will make a huge difference in handling on the street. If you have a late model disc brake set up the swaybar mount is in a different location. That bar went trough the K instead of around and under.
Hmmmmm new control arms and and old K frame. I may not be able to get one anyway with the mish mash of parts.
