switching 14" axels to 15"
gotdust57@yahoo
i have a 73 duster with 489 8.75 3.55 suregrip and would like to get bigger tire on for better traction, i have 14" tires now and would like to maybe put 15" tires on back, can i just switch axels to fifteen inch or is there another solution to my problem, if i stay with 14" what is widest and tallest tire i can put on without hitting springs, any ideas are welcomed? thanks
You don't change the axels. You change the wheels as long as the bolt pattern is the same. Really, if you want to keep your 14" wheels you can go to a taller tire. Check out what M/T has to offer.
Jack
