Thanks guys for the replies,
I'm listening
it's been over a year trying to find an answer to this problem
It started when we put the stroker in with stock leaf springs
it shook so hard
the passenger front window fell out of its mount... lol
it hops so bad, just knew we were going to break the 8 3/4. small joints. 4.56
during the off season (2013)
is when we put the 4.10 dana in (moved 2" forward)/ stiffer springs
lighter wheels, ET pro
Same results
after trying the snubber Aug. 2014, ran out of ideas.
looking at the four wheel drive
noticed the flat bottom spring
so took a set. cut the back half off and tried that
this pic was an attempt to get a long shock in there because we found out early that the shock was bottoming,
thought that was the whole problem
before buying an adjustable shock. $$$
we have 11" eye to eye
all the shocks we have need 14" to install
even tried mount the shocks in front on the axle
Nov 22, this year
found a track open
we had cut the bump stops/ lower the front, reset the toe.in
hated have to drive thru the water box.
the only thing that helped that day was retard the timing
What fun is that?????
We have a 68 Satellite
540
dana 4.56
stock shocks, stock leaf springs
NO hop
just breaks parts lol
first was break the rear yoke off
next sheared the teeth off the pinion,
then it turned the tubes in the dana
We then got a moser Dana with 1350 yokes and joints
So far, held up
Thats' when we thought to build the Dart> lighter car, easier on parts
