Need someone with more knowledge than me please...
Putting a 71 swinger back together and came across a weird issue
Tail lights, brake lights, blinkers, plate light all work fine with the head lights off.
Turn the head lights on and everything goes haywire. Back-up lights burn when you hit the brakes, left tail burn bright without touching the brakes, blinkers flash the back-up lights, plate light stops working, and back-up lights don't work in reverse.
Bulbs are fine, voltage at the factory harness reads correct, no exposed wires, no problems with front lights or markers it all looks good.
Where are the factory grounds located? Any other ideas?
