So yes this is the new Ron Francis wiring kit. I’ve called them and there even stumped. Checked over all the wiring on how they want you to do it and it all checks out. I even installed a new brake switch just in case for the brakes. So once I connect the battery the tail lights turn on and the daylight lights turn on for the front in the grille. The key isn’t turned and the brake switch is set correctly. I did notice on their diagram that the brakes are connected staight to battery on the fuse panel. The only way to get lights to turn off is to pull the fuse to the tail lights and that even turns off the daytimes up front. I’m stumped. If anyone has any ideas to why both of them turn on please let me know even if they are out of left field. I did notice that they didn’t give me any wiring for the hazard switch. And honestly I’m not even sure what it’s supposed to even look like. By the way the lights are always on no blinking. Even when I turn on the turn signal. Still solid lights....
