taillight/brake/blinker problem
chingon69
Member
manahattan,il
All my wiring problems are in the rear. i have no turn signals. when i turn the left signal on its just solid. and i get nothing from the right. the only brake light i have is the right. i had taillights, license plate lights until i changed the wiring harness. now i have all the same problems plus no more taillights or plate lights. what am i missing
Well for starters what year/ model are you working on?
What do you have for shop manual/ wiring diagrams?
Do the front turn work? The dash indicators?
Have you checked for brake light power coming out of the brake light switch?
There are a couple of "major" spots to check for power
No1 probably most important is the column connector for the turn signal switch
No2 is probably the connector in the kick panel where the rear harness joins and heads to the rear
Once you have checked the items listed by 67Daart273, and made sure each light socket has a good ground; I wouldn’t discount directional light switch as a possible cause of these problems.
