Great build. I´ve got a -90 Le Baron that I´m thinking of to put a SB in but am unsure of if doable. Guess I´ve found the answere. :burnout:. What kind of K-member are you using?
Thanks for the info. :thumbup:I bought the kit from Kenny Exline. Then I cut the whole floor out fabbed the frame from 2 x 3 rectangle tubing 3/16 wall and bought the triangle 4 link and coil over shocks, 8.8 posi rear 3:73 gears, I build my own transmissions so a A-500 in it and gave her heck !! To make a long, long:burnout: story short.... Thanks !
I bet Tony Fields will get a kick outta that.
