Tank Removal Day
Troub
67 Dart 270, 225 slant six
Florida
Removed the gas tank today, managed it without messing with removing the filler neck. Just put two jacks underneath, removed the strap, then slowly lowered. About halfway down I gave it a light leg press from the drivers side end and it dropped right off. Just lowered and removed at that point. Left a bit of gas in it for weight and I think that helped gravity do it's work. Pics...
Checked filler neck for damage and all looks good. Not having to remove it was a nice time saver. Pic of neck underneath...
Hello Troub
Looking good.
re-use the insulator that is on the top of the old tank if you can.
Put a little lube on the filler neck so the grommet slides on nice and sweet.
Keep us updated.
Happy Mopar :)
Arron
Easy removal, but I don't know about the other way! It would definitely be much easier to install the tank and then shove the filler neck into it.
Hello Troub
Looking good.
Keep us updated.
Happy Mopar :)
Arron
Will do.
Yeah I am wondering if it will go on as easy as it came off!
NOPE, DONE IT BOTH WAYS . NOT FUN AT 70 PLUS YRS OLD. Use plenty of lube on the gasket and tube . I was lucky and didn`t have a leak .
