65cudalover
Newly rebuilt motor with holly carb and electronic ignition/orange box. The car is a 65 cuda formula s. Sometimes the car will not start it seems to flood out carb if I touch gas at all, other times it just cranks over and wont start if I do not touch gas. Other times it cranks and will start if I just barely touch gas? I am pulling my hair out trying to figure out what is the deal. Is it the carb? Is it coil? Is it something else electrical? I am bewildered. If it starts it runs fine, I ran it last week for over an hour just cruising around, went to start yeasterday and no go. I tried again this morning hoping to cruise this evening to car hang out and no go. I tried so much the battery now is being recharged. I am feeling like maybe a different/new carb may be in order, but hate to spend money if I do not have too? Help me if you have some suggestions on what to check. I know carb was fine before just tempermental with gas pedal when starting and no backfire to harm power valve. I now submit to your vast wisdom as I am lost.....
