Template for hole in the hood
72ScampTramp
Scamp Tramp
Fort Dodge Iowa
Im running dual carb tunnel ram. Im in the middle of doing body work and dont have the engine for mock up. Anyone have a template for cutting the hood hole for clearance on a 72 Scamp or similar.
Two six inch holes, or cut out the middle triangle like I did. I imagine there are templates, but if you have your mounting location, you can easily see where to cut.
I would not depend on someone else's template. Your engine might "sit a little different."
Cardboard, maybe some scrap wood, just jig it up
I have a Dart Sport, but I'm sure the hoods are similar. I needed clearance to clear my carb and filter, and I always toyed around with velocity stackes, so I cut a larger opening than the two six inch holes. I didn't want to cut supports and weld in new ones, so I cut at the factory triangle. Here are some shots of what I did, and there is a ton of room.
The area cut out.
Close up of the hole cut out and the underside of the scoop.
The top side, finished and hot looking!
