Not sure what you are getting at. If you are trying to check out the wiring "in place," not so much. If you are only attempting to figure the function of the switch, yes
Look at the wiring diagram.
You have TWO power sources going IN.
One powers ONLY the headlights, so those two contacts are only made in "full on" headlights, and make no contact with any other terminal
The second power source goes to the switch from your tail fuse
This powers tail, park, and the dash lamp dimmer. So with the switch in "park" all of those terminals will show continuity with each other.
The switch contacts should be marked on the switch. If not, refer to the pictorial in the wiring diagram
Using resistance to check an in-place harness is somewhat more difficult because of feedback etc in some circuits. A far better way is to hook everything up "safely" for testing, except the battery ground. Then hook a LARGE 12V lamp in series with the battery NEG terminal to ground. Use a headlamp, if you have nothing else, a stop / tail lamp with the two filaments in parallel. This will protect everything against shorts while testing.
