The coax/ antenna combination is subject to extremely high impedances. To put this in perspective, a CB antenna, at 27.x mhz, is "about" 9' high for a "quarter wave." and is a "somewhat" match for 50 ohm coax
By comparison, a 550khz radio station, to be the equivalent "quarter wave" would have to be in the vicinity of 400-450 feet!!!
So your 40 some-odd INCHES whatever antenna sees extreme and complex impedances and operates "mismatched"
WHAT DOES THIS MEAN
Simply this means that BECAUSE this is such high impedance (You could not measure the standing wave, LOL) any dirt/ moisture/ other intrusion into the coax/ terminations will attenuate your signal very badly
HOW TO TEST?
Probably the simplest way is if you have access to a "megger" (high voltage leakage tester) at work, friends, etc. Otherwise, only thing you can do is test for "open" between center and ground on the coax, and continuity from ground at connector to mounting threads, and continuity from center terminal at connector to the antenna itself
(A megger is a high voltage ohmeter designed to find "breakdowns" in motor insulation, and can operate depending on model, up to 600V and more)
