HowardBishop
Thank you to all the MOPAR men who gave me VERY helpful ideas to unfreeze a 318 motor. IT WORKED!!!! It took three weeks....probably easier to tear it apart and start rebuilding.....but....here's what I did...
pulled plugs..
disconnect belts....
filled pistons with Deep Creep, Marvel Mystery Oil, diesel fuel, WD-40, transmission fluid.......as much as a piston would hold.....
put a half inch breaker bar and socket on the crank bolt....
hooked a come-along around the breaker bar and around the shock tower...
put some pressure on the bar....left it over night....
unhooked the come-along....rocked the bar counterclock wise and then clockwise....
hooked the come-along back up....repeat for a couple days of pressure...
IT MOVED slightly!!!!
Continue the come-along....rocking-bar procedure.....More and more give and the motor began to turn.
I put an extension on the breaker bar for more hand -arm pulling ....pushing......Yesterday I completed the full rotation using the breaker bar and extension.....NOW IT TURNS EASILY WITH THE BREAKER BAR!!
Next step.....try to start it.
Any way....many thanks for nearly 20 responses to my problem...here's a real success story!!! The steady come-along pressure was the key....Thanks to God for that additional idea!!!!
Howard
pulled plugs..
Howard
