that was fast!!
melcardona
texas
so what are your thoughts ...............if you can find a poly tank and be willing to cough up the greed charge..then this thread is kinda a mood point discussion...but for those of us that will stick with the steel tanks.... they are cheep....would you spend the money to pre coat the inside before installing the new steel tank??....when i first insp the under carrage of the 64..one of the first things that caught my eyes was ...nice new tank!.....last wk i took of the sending unit..not working.....was ready to r n r it....took a look see in the tank....oh crap..heavy wall flaky rust.....wow that was fast...8 yrs junk tank....made in canada /..no better then the china junk...there was only 3 gal in it..it was still very volatile fuel..big poof larg flame when lit....the smell told the true story....weather you can buy non ethanol or just remove it..fact is there will still be some in it...and its a killer on steel tanks..unless its a daily driver and full most the time imso.............ive used pour 15 tank sealer half doz times...when i built tanks for those rides that none could be found...and 1 lightly rusted oe tank from the 70s..........seam to work fine....now that im 10 mi from the gulf of america...and will get 1 to 3 days of sea air a month....if it where you...would you coat this tank??? keeping it full no issue...car might run once a wk??? might.....will i try to only put non enthanol in it..but will loose that battle.........your thoughts???
Understand the concern. I run a blend of 87 ethanol free and 100LL aviation fuel in mine. Does not get driven much at all so trying to prevent the rust issue. No complaints so far. Will let you know next spring. If I could get 93 octane ethanol free would run that exclusively.
I have NO proof, but I have read that after several years the coating can start to release and cause more problems. You may want to check further into this .
Not sure it is needed, but I only run non ethanol gas in my car.
Yote
Yo
Yote
well ive known it to be fine to about that long....preping the tank is everything
LAST thing you want to do is slosh the interior of a fuel tank! It will just come back to bite you in the azz....
oh i agree....but leaving the inside of a tank full of rust/varnish will most definitely make for a long walk home at some point....better to just deal with it and get it right...
Ive known guys to coat the inside of their motorcycle tanks with that stuff, only to have it start to flake off down the road and reek havoc on the fuel system. I wouldnt recommend sealing a fuel tank with anything.
im not going to say its always the best choice...but one fact remains.....if you dont follow the directions to the tee...it can loose its adhesion..the net is full of bikers on both sides of the subject
Get back to us in 4 or 5 years. At least it's not an airplane. I've lost track of how many of those, that guys sloshed tanks, that the Wife and I have hauled out of the bush in the past 30 years....
Tree...
No I'm stating the **** doesn't work in brand new, clean freshly built tanks where guys didn't trust their sealing process and sloshed "just in case". I'll say it again, it'll come back to bite you in the azz.... at least you can coast to the side of the road !!
