rokketride
- Joined
- Jan 26, 2008
- Messages
- 45
- Reaction score
- 0
If you want to get your QA1 set from Summit, 10% off Code 2RETYV makes them $125.95 each.
So the 318 W/air springs are the same as the 340? Or should I add them to the upgrade list also? And are Poly bushings good for the rear springs(I've heard conflicting reports)?
And Autox... Are those single or double adjustable?
KOOL....I decided.....and I Just now ordered those shocks...
You're running an alterkion, right? What spring rate are you running up front? What spring rate are you running in the rear?
Hey Autox, I'm running the AlterKation on my '70 dart. NOT the '68 Barracuda that I'm rebuilding the front suspension on....I THINK the spring rate that I'm using on the Dart with the Alterkation is the 450# spring rate....
Which one did you buy the shocks for? What is the spring/T-bars in that one?
