64physhy
I picked up my stroker today from Brian (ou812) at IMM Engines. He was just shutting it down from the break-in when I got there. After letting it cool down a while, he did the dyno pulls. The first couple pulls were good, but not full pulls(only to 5K RPM). Even only going to 5K, it made good power, but not getting over the 500 HP mark (torque was in the 520's).
He did several pulls, changing jets and timing in between. Ended up with 525 lb/ft (4400 RPM) and 512 HP (5800 RPM) in the end. These were not the highest peak numbers of the day, but did have the smoothest curves, so it's what we stayed with. Ave torque is 486, ave HP is 417. I'll get scanned results up later.
Ended up with timing at 31, Holley 950HP jetted 77/79.
Cam is Comp XE295HL 251/257, .564 (with corrected lift right around .600 with the 1.65 rockers and taking angles into account)
Everything else, is the same parts I had in it before.
I really wish I had gone to Brian in the first place- it would have saved me A LOT of money in the long run. THANKS BRIAN!
