themoquad find ..I'd help
nutz
washington nj
so bought a remain 72 340 been sitting 20 years ? never started ....
he had a box of themoquads 3
not going to use them but could use help i'd them they need some tlc ...ill post a for sale post if they are worth it
and bought this new never out of the box avs .....
thanks nutz ....
thanks nutz ....
The Thermo-Quads pictured are as follows:
  • 6452S = 1974 360 high performance, manual transmission. Federal applications. Chrysler #3751433. Built on August 22, 1974.
  • 9342S = 1982 318 Truck. Federal applications. Chrysler #4287013. Built on December 8, 1981.
  • 9377S = 1981 360 Truck heavy duty cycle. Federal applications. Late production. Chrysler #4213714. Built on December 13, 1981. Service replacement unit.
The 6452 would be the pick of the bunch, earlier model, less pollution crap. If the pri bores are 1.5", then it is the 850 cfm version.
It should have the larger primaries.
I would be interested in buying it if reasonable.
I have a bunch of the other ones.
Numeric Listing Abbreviations​
Following are abbreviations used in the Numeric Listing and in other areas in this document.
AT = Automatic Transmission
MT = Manual Transmission ( No reference means both transmissions )
Pri. = Primary Jet
Sec. = Secondary Jet
Rod = Primary metering rod
Bore = Primary throttle plate diameter in inches, All secondaries are 2-1/4"
HP = High Performance
CA = California application; generic for CA, N95
Fed = Federal application ( No reference means both Federal and California.)
Can = Canada application. Typically, Canada used Federal carburetors except as noted.
Exp = Export
AU = Australia
Mex = Mexico
LD = Light Duty Cycle
MD = Medium Duty Cycle
HD = Heavy Duty Cycle
LRT = Li’l Red Express Truck
MH = Motorhome
LB = Electronic Lean Burn or ESA. Noted on 1976 models.
After 1976, most Federal cars were LB equipped (N92, N94).
IE = Idle Enrichment
Alc = Altitude Compensator; (N96).
HA = High Altitude; Can include Alc, or just revised jetting, et. al.
BV = Bowl Vent valve
O2 = Oxygen feedback solenoid
CN = Application listed, but production canceled after application specified.
NR = Application listed, but not released in production after application specified.
NB = Application listed, but not built after application specified.
NOTE: N92, N94, N95, N96 are Chrysler sales/production codes for air/emissions packages.
Numeric Listing​
ModelApplicationDetailsPri.Sec.RodBoreKit
4846SCompetition Series850 CFM3313416151-1/28
4846SACompetition Series850 CFM308031166151-1/28
4847SCompetition Series1000 CFM3313416161-1/28
4847SACompetition Series1000 CFM308931166161-1/28
497271 340MT (3512820)307431256551-3/86
497371 340AT (3512821)307431256551-3/86
609072 400AT Fed (3614139)4095513719371-1/21
613872 340MT Fed (3614122)4095513719401-3/81
613972 340AT Fed (3614123)4095513719401-3/81
614072 400MT Fed (3614138)4095513719391-1/21
614472 340AT Exp4095513719501-3/81
616572 400MT CA (3614172)4095513719381-1/21
616672 400AT CA (3614173)4095513719381-1/21
631873 340MT Fed (3698327)4098513719621-3/81
631973 340AT Fed (3698328)4098513719661-3/81
632073 400HP MT Fed (3698332)4098513719651-1/21
632173 400HP AT Fed (3698333)4098513719661-1/21
632273 440 Car & TruckAT Fed (3698334)4098512519661-1/21
632473 440HP AT Fed (3698336)4098512519661-1/21
633973 340MT CA (3698339)4098513719621-1/21
634073 340AT CA (3698340)4098513719661-1/21
634173 400MT CA (3698342)4098513719651-3/81
634273 400AT CA (3698343)4098513719661-3/81
639472-73 340AT Exp/AU (3614851)4095513719411-3/81
641073 440 Car & TruckAT CA (3698319)4098512519661-1/21
641173 440HP AT CA (3698329)4098512519661-1/21
6446M-440Chrysler Marine (3698397)4098512519651-1/29
645274 360HP MT Fed (3751433)4098514319621-1/21
645374 360HP AT Fed (3751434)4098514320051-1/21
645474 360HP MT CA (3751435)4098514319621-1/21
645574 360HP AT CA (3751436)4098514320051-1/21
645674 400HP MT Fed (3751439)4098514319661-1/21
645774 400HP AT Fed (3751440)4098514319661-1/21
645974 400HP AT CA (3751441)4098514319661-1/21
646074 440AT IE HA Fed early (3751443)4098513719661-1/21
646174 440AT CA early (3751444)4098513720051-1/21
646274 440HP AT Fed early (3751445) NB4098513719661-1/21
646374 440HP AT CA early (3751446)4098513720051-1/21
6468Production Canceled-------------------
648874 360AT CA early (3751451)4098514319661-1/21
648974 400AT Fed early (3751452)4098514320051-1/21
649674 400AT CA (3751453)4098514320051-1/21
650374 400AT Exp (3751454)4098514319661-1/21
6518H-440-3Chrysler Industrial (3698398)4098513719651-1/29
654574-77 440-1,-3 TruckFed (3751472)4098513720241-1/21
655074 345IHC AT CA (448581C91)4098511020201-3/81
655174 392IHC AT CA (448682C91)4098511020201-3/81
656874 460Ford AT CA (D4AE-BB,BC)4101509820141-3/87
659074 392IHC Fed (451872C91)4098511020201-3/81
659174 345IHC AT CA (451915C91) -> 65924098511020201-3/81
659274 392IHC MT CA (451916C91)4098511020201-3/81
6614Not Builtuse 90224098514319661-3/8-
661574 440-1 TruckAT4098513720241-1/21
661674 440-1 TruckAT CA NB4098513719661-1/21
900074 318Exp (3751474)4098513719661-3/81
900275-76 360HP AT Fed IE (3830529)4095514319981-1/22
900475 360AT CA IE HA early/Mex (3830531)4095512520861-1/22
900875 400AT CA IE early (3830535)4098514319651-1/22
900975 440AT Fed IE (3830536)4098513721091-1/22
901075 440AT CA IE (3830537)4098513719651-1/22
901175 440HP AT Fed IE (3830538)4099513721031-1/22
901275 440HP AT CA IE early (3830539)4098514319651-1/22
901374 360AT CA late (3751420)4098514319661-3/81
901474 400AT CA late (3751419)4098514320051-1/21
901574 440HP AT late (3830415)4098513720051-1/21
901674 440HP AT CA late (3830416)4098513719661-1/21
901774 440-1 TruckAT CA (3830417)4098513719661-1/21
9019Production Canceled------4098514320051-3/81
9020Production Canceled------4098514319661-3/81
9021Production Canceled------4098513719661-3/81
902274 360 TruckAT CA (3830401)4098514319661-3/81
902374 440AT Fed late (3830403)4098513719661-1/21
902474 440AT CA late (3830404)4098513720051-1/21
902574 440-1 TruckAT Fed (3830405)4098513719661-1/21
902675 345IHC Fed (459642C91) CN-------------
902775 392IHC Fed (461280C91)4101511020911-3/81
902875 392IHC CA (461281C91)4101511021321-3/81
902975 446IHC Fed CN-------------
903075 446IHC CA CN-------------
903475 440-1 TruckMT Fed (3870944)4099514319651-1/21
903575 440-1 TruckMT CA (3870945)4100512521101-1/21
903675-76 440-1 TruckAT CA (3870946)4100512521101-1/21
904475 345IHC CA CN-------------
9045Production Canceled-------------------
904675 400AT Fed IE early (3830554)4099514319651-1/22
904775 392IHC CA (461283C91) CN4099514319651-1/2-
9048Production Canceled-------------------
904974 440HP AT CA late (3830864)4099514319651-1/22
905075 400AT Can IE (3830561)4099514319651-1/21
905175 440AT Can IE (3839562)4095512521441-1/22
905275-76 440HP AT Can IE(3830568)4095513720241-1/22
905375 400AT CA IE PDC-SW(3830570)4100514319651-1/22
905475-76400 HP AT Fed IE (3830569)4098513720051-1/22
905576 360AT CA IE (4006624)4096512519621-3/82
905675 400SW AT CA IE (4006625)4099514321451-1/22
905776 400AT Can IE (4005626)4099514319651-1/22
905876 440AT Fed IE (4006631)4099513721091-1/22
905976 440AT CA IE (4006632)4099513721451-1/22
9060Production Canceled-------------------
9061Production Canceled-------------------
906276 440HP AT CA IE4098513721531-1/22
906375 440AT CA early (3830580)4099514319651-1/22
906476 400AT LB4099514319651-1/22
9065Not built------4098513721091-1/22
906676 440HP AT Fed IE4099513721031-1/22
9067Production Canceled-------------------
906875 400AT CA late (3830590)4099514321451-1/22
906975 440AT CA late (3830585)4099514321451-1/22
907176 351Ford XC AU MT (76DA-AA)4101510121731-3/87
907275 360AT CA late (3830503)4099514319651-1/22
907375 440AT CA late (3830507)4098513721451-1/22
907476 400AT CA (4006642)4099514321451-1/22
9075Production Canceled-------------------
907677 360HP AT CA Alc IE (4027735)4092513719381-3/82
907777 400HP AT Fed (4027736)4098514321591-1/22
907877 440AT Fed IE (4027737)4098513721591-1/22
9079Production Canceled-------------------
908077 440HP AT Fed IE (4027739)4098513721791-1/22
908177 440HP AT CA IE CN4098513719501-1/22
908576 351Ford XC AU AT (76DA-JC)4101510121371-3/87
909176 302Ford XC AU MT (76DA-JE)4101509821741-3/87
909276 302Ford XC AU AT (76DA-KC)4101509821741-3/87
909377 360HP AT Fed Can IE (4027742)4092514321951-3/82
909476 440HP AT Fed (4006648)4099513721031-1/22
909576 440HP AT CA (4006649)4098513721531-1/22
909677 440 TruckAT CA (4041553)4099512521101-1/21
909776 400AT LB (4006654)4099514320861-1/22
909976 400AT CA late4099514321451-1/22
910076 400AT Can late4099514321441-1/22
910177 440AT CA IE (4027750)4098513722101-1/22
910277 400HP AT Fed4098514321591-1/22
910377 400HP AT Fed (4027761)4098514322111-1/22
910478 360AT Fed IE BV (4041826)4092511019401-3/83
910878 400AT Can Exp (4041836)4098514321591-1/23
910978 440AT Fed IE early (4041830)4098514321591-1/23
911078 440AT Fed HA CA IE BV (4041831)4098514319651-1/23
911178 440AT Can Exp IE (4041837)4098513721591-1/23
911278 440HP AT IE BV (4041832)4098512521791-1/23
911477 440AT Can (4027763)4098513721591-1/22
911577 360AT Alc (4027727)4092513719381-3/82
911678 440 TruckMD IE CA (4095406)4098513719501-1/23
911778 440 TruckHD CA (4095407)4099512521101-1/23
911878 440 TruckHD (4095423)4098512521101-1/23
911977 440HP AT CA IE (4027770)4098512519501-1/22
912378 318 TruckMT CA (4095427)4092511019971-3/83
912478 318 TruckAT BV CA (4095428)4092511019971-3/83
912578 360 TruckMT CA (4095429)4092511019381-3/83
912678 360 TruckAT CA (4095430)4092511019381-3/83
912777 440AT4098512521791-1/22
912879-80 345IHC AT (490561C91)4095509822731-3/84
912979 345IHC MT Fed (490560C91) CN-------------
913079 345IHC AT CA CN-------------
913179 345IHC MT CA CN-------------
913279 345IHC AT HA CN-------------
913379 345IHC MT HA CN-------------
913478 360AT Fed HA CA IE (4041856)4092511019961-3/83
9135Production Canceled------4092511019961-3/83
913678 360Mex (4041855)4092511021951-3/83
913778 318AT Can Exp (4041858)4092511019981-3/83
9138Production Canceled------4098514321951-3/83
9139Not Released------4098511021531-3/83
914078 400AT Fed (4041861)4092513719971-1/23
914176-77 351Ford Truck AU MT (76DA-KE)4101510121731-3/87
914276-77 351Ford Truck AU AT (76DA-NC)4102510121731-3/87
914376-77 302Ford XD AU MT (76DA-ND)4101509821741-3/87
914476-77 302Ford XD AU AT (76DA-PC)4101509821741-3/87
914578-79 351Ford XD AU MT (76DA-PE)4101509522721-3/87
914678-79 351Ford XD AU AT (78DA-BA)4101509522721-3/87
914778 318AT CA (4041865)4092511019961-3/83
914878 440HP AT CA IE CN4092511019961-1/23
914978 440 TruckMD AT CA (4095440)4098513719501-1/23
915078 440 TruckHD AT CA BV (4095441)4099512521101-1/23
915178 440 TruckHD AT (4095442)4098512519981-1/23
915278 318 TruckAT LD Can (4095447)4092511019971-3/83
915378 440HP AT CA (4041874)4092511019961-1/23
9154Production Canceled------4098513719651-3/83
9155Production Canceled------4092511019961-3/83
9156Production Canceled------4092511022781-3/83
9157Production Canceled------4098511019651-3/83
9158Production Canceleduse 9196-------------
9159Production Canceleduse 91974098511019501-3/83
9160Production Canceleduse 9198-------------
916178 440AT Can Exp (4041879)4098511020141-1/23
9165Production Canceled------4095511022781-1/23
9166Production Canceled------4095511022711-1/23
9167Production Canceled(4104471)4095511022711-1/23
9168Production Canceled(4104472)4095511022711-1/23
9169Production Canceled(4104473)4095511022711-1/23
9170Production Canceled(4104474)4092511019961-1/23
9171Production Canceled(4104475)4092511019961-1/23
917279 360 LRTLD MD BV IE (4104482) CN4098513720051-3/83
917378-79 360 LRTHD (4095418)4098512519981-3/83
9174Production Canceled(4104476)4095513521451-3/83
9175Production Canceled(41044774095512521451-3/83
9176Production Canceled(4104478)4098512521451-3/83
9177Superseded by 9210(4104479)4098512521451-3/83
9178Production Canceled(4104480)4099512521451-3/83
9179Production Canceled(4104481)4099512521451-3/83
918078 440AT BV IE Fed (4041881)4098513721591-1/23
9181Production Canceled------4092511022781-1/23
918278 400AT Fed BV (4041882)4092513719961-3/83
918378-79 318 TruckBV (4104483)4092511019971-3/83
9184Production Canceled(4104487)-------------
918578-79 318 TruckBV (4104484)4092511019971-3/83
918778-79 318 TruckBV (4104489)4092511019971-3/83
918878 400AT Can Exp (4041892)4098514321591-3/83
9189Production Canceleduse 9227-------------
919078 440 TruckMD AT CA BV (4104492)4098513719501-1/23
9191Not built------4092511019961-3/83
9192Production Canceleduse 9198-------------
919378-79 360 TruckMT HD CA BV (4173316)4092511019381-3/83
919478-79 360 TruckAT HD CA BV (4173317)4092511019381-3/83
919579 318AT CA IE BV (4095934)4092511019381-3/83
919679 360AT Fed IE BV (4095935)4095511019651-3/83
919779 360AT Can IE BV (4095936)4095511019501-3/83
919879 360HP AT CA IE BV (4095937)4095511019501-3/83
9199Production Canceleduse 9228-------------
9201Production Canceled-------------------
920279 360AT CA IE BV (4095939)4095511019501-3/83
920380 345IHC AT Fed (1700004C91)4095511021441=3/84
920480 345IHC MT Fed (1700005C91) CN-------------
920580 345IHC AT CA (1700009C91)4095511021441=3/84
920680 345IHC MT CA (1700010C91) CN-------------
920779 360 TruckHD (4173301)4097512522931-3/83
920878-79 360 TruckHD BV (4173302)4097512522931-3/83
920979 360 Truck ATHD (4173303)4100512521451-3/83
921078-79 360 TruckAT HD BV (4173304)4100512521451-3/83
921179 440 TruckAT HD (4173305)4100512521101-1/23
921279 440 Truck HDAT CA IE BV (4173306)4100512521101-1/23
921378 440 TruckHD4100512521101-1/23
921478 440 TruckHD CA BV (4173308)4100512521101-1/23
921578 318 TruckMT BV (4173309)4092511019971-3/83
921678-79 318 TruckAT BV (4173310)4092511019971-3/83
921778-79 360 TruckHD BV4092511019381-3/83
921878-79 360 TruckMT HD CA BV (4173312)4092511019381-3/83
9219Production Canceled------4092511019971-3/83
922178 440 TruckAT HD (4173313)4098512519981-1/23
922278-79 318 TruckMT BV Fed (4104495) CN4098511019971-3/83
922378-79 318 TruckAT BV CA (4104496)4097511021451-3/83
922479 360 TruckLD MD BV CA IE (4104497)4092511019961-3/83
922579 360 TruckLD MD BV CA IE (4104498)4092511019961-3/83
922679 360 LRTLD MD BV IE (4104499)4098513720051-3/83
922778-79 318 TruckAT Can BV (4104500)4092511019971-3/83
922878-79 318 TruckMT CA BV (4173330)4092511019961-3/83
922978-79 318 TruckAT CA BV (4173331)4092511019961-3/83
923080 318AT Can Exp BV (4179033) CN4092511022781-3/83
923280 318AT Can BV (4179035) CN4092511022781-3/83
923480 318AT Fed BV O2 (4179037)4093511019501-3/83
923680 360AT Can BV (4179039)4093511019501-3/83
9237Production Canceled------4098511019381-3/83
923879 360AT Mex4096512520861-3/83
924079 446IHC/Dodge MH AT Fed (4173346)4101511019401-1/23
924179 446IHC/Dodge MH AT CA (4173347)4101511019401-1/23
924380 318AT Can Exp BV (4179043)4095511020001-3/83
924480 360AT Fed BV Alc (4179044)4101511021271-3/83
924579 318AT CA BV (4095495)4092511022781-3/83
924679 360AT CA BV IE (4095496)4095511019501-3/83
924779 440 TruckAT Fed (4173344)4099512522981-1/23
924879 440 TruckAT CA (4173345)4099512522981-1/23
925079 360AT CA BV (4095978)4095511019501-3/83
925180 360 TruckAT MD CA (5214807)4092511019961-3/83
925280 360 TruckMT MD CA (5214808)4092511019961-3/83
9253Production Canceled------4092511019961-3/83
925480 318 TruckCA BV (5214810)4093511019961-3/83
925580 360 TruckLD MD Fed4099513720051-3/83
925679 318AT Fed Alc (4095979)4092511020051-3/83
9261Production Canceled------4099512519971-3/83
926580 360 TruckAT LD MD Fed (5214821)4097511020861-3/83
926680 360 TruckMT LD MD Fed (5214822)4097511020861-3/83
9267Not built------4092511022781-3/83
926879 360 TruckLD MD BV IE4095511019501-3/83
926978-79 318 TruckAT CA BV (4173361)4092511019961-3/83
927078-79 318 TruckAT CA BV (4173362)4095511021451-3/83
927178-79 318 TruckAT Can BV (4173363)4092511019971-3/83
927279 360 TruckAT MD CA BV IE (4173364)4092511019961-3/83
927379 360 LRTAT LD MD BV IE (4173365)4098513720051-3/83
9274Not built------4092511019961-3/83
927578-79 360 TruckHD CA BV (4173366)4098512520241-3/83
927678-79 360 TruckHD CA BV (4173367)4098512521101-3/83
927779 360 TruckHD BV (4173368)4096512520241-3/83
927878 360 TruckAT HD BV (4173369)4098512521101-3/83
927980 318 TruckBV (5214823)4098512520051-3/83
928080 360 TruckLD MD BV Fed NB4104511023261-3/83
928180 360 TruckHD CA BV (5214826)4104511023261-3/83
928280 360 TruckBV4104511023261-3/83
928381 318AT BV Fed (4179132)4096511023601-3/83
928481 318AT BV Can Exp (4179133)4095511020141-3/83
9285Production Canceled------4092511019501-3/83
9286Production Canceled------4095511020001-3/83
9287Not built------4097511020861-3/83
928880 318 TruckLD AT Can (5214834)4092511019961-3/83
928980 446IHC/Dodge MH AT BV CA (5214829)4101511023281-1/23
929080 446IHC AT BV (1700424C91)4101511023391-1/23
929180 446IHC/Dodge MH BV (5214842)4101511023391-1/23
929280 360 Truck(5214836)4099512519971-3/83
929381 318AT BV O2 Fed (4179145)4096511023601-3/83
9294Production Canceled-------------------
929580 318AT BV Fed Alc (4179051) CN4092511019961-3/83
929680 318 TruckMD HD CA BV (5214840)4092511019961-3/83
9297Production Canceled-------------------
929880 360 TruckMT LD MD Fed (5214841)4094511019961-3/83
929980 360 TruckMT LD MD Fed (5214845)4094511019961-3/83
930480-81 360Mex4096512520861-3/83
930580 360AT Fed BV4101511021271-3/83
930680 318AT O2 BV Exp4092511022781-3/83
930781 345IHC AT Fed (1700643C91) CN-------------
930881 345IHC MT Fed (1700644C91) CN-------------
930981 345IHC AT CA (1700650C91) CN-------------
931081 345IHC MT CA (1700651C91) CN-------------
931181 318Truck LD AT Fed (4213731)4097511023591-3/83
931381 360Truck AT Fed4097511020861-3/83
931481 360Truck MT LD MD Fed (4213752)4097511020861-3/83
9316Production Canceled------4095511023401-3/83
9317Production Canceled------4095511023401-3/83
9318Production Canceled------4095511023401-3/83
9319Production Canceled------4095511023401-3/83
932080 318O2 BV4096511023401-3/83
932180 351Ford Truck AU MT (78DA-CA)4101509523631-3/87
932280 351Ford Truck AU AT (78DA-DA)4101509523631-3/87
9323Production Canceled------4097511023601-3/83
9324Production Canceled------4097511023421-3/83
932581 360 TruckLD Can AT (4213781)4092511019961-3/83
932682 360 TruckLD MD Fed4097511020861-3/83
932783 360 TruckLD MD Fed4097511020861-3/83
932881 360 TruckAT CA (4213793) CN-------------
932981-82 318 TruckLD CA AT (4213743)4097511023591-3/83
933081-83 318 TruckLD CA MT (4213744)4097511023591-3/83
933182 360 TruckLD MD CA Alc MT (4213763)4092511019961-3/83
933283 360 TruckLD MD CA Alc AT (5213764) CN4092511019961-3/83
933382 302Ford XE AU AT (78TA-BB)4101509823541-3/87
933482 302Ford XE AU MT (78TA-CB)4101509823541-3/87
933582 351Ford XE AU AT (80TA-AA)4102510121731-3/87
933682 351Ford XE AU MT (80TA-AB)4102510121731-3/87
9337Production Canceled------4096511023601-3/83
9338Production Canceled------4096511023601-3/83
9339Production Canceled------4097511023591-3/83
934080-81 360Mex4096512521591-3/83
934183 318 TruckLD (4287012) CN4098511023591-3/83
934282 318 TruckFed BV (4287013)4097511023591-3/83
9343Production Canceled------4097511023591-3/83
9344Production Canceled------4097511023591-3/83
9345Production Canceled------4092511019961-3/83
9346Production Canceled------4092511019961-3/83
9347Production Canceled------4097511020601-3/83
9348Production Canceled------4097511020601-3/83
9349Production Canceled------4095511023401-3/83
9350Production Canceled------4095511023401-3/83
9351Production Canceled------4097511023591-3/83
9352Production Canceled------4097511023591-3/83
9353Production Canceled------4097511023591-3/83
9354Production Canceled------4097511023591-3/83
9355Production Canceled------4097511023591-3/83
9356Production Canceled------4097511023591-3/83
935781-83 318 TruckMD HD (4213745)4098511020051-3/83
935881-82 360 TruckHD (4213753)4104511023261-3/83
935981-83 360 TruckHD (4213754)4099512519971-3/83
936481-84 318AT Can BV O2 (4179177)4095511020141-3/83
936583 318 TruckAT LD (4213703)4097511023591-3/83
936684 360 TruckLD MD Fed (4213704)4096511020861-3/83
936781 318 TruckMT LD (4213706)4097511023591-3/83
936881 318 TruckAT LD BV CA (4213707)4097511023591-3/83
936984 360 TruckLD MD CA Alc (4213708)4092511019961-3/83
937084 360 TruckHD CA (4213709)4104511023261-3/83
937181 318 TruckMD HD BV Fed (4213713)4096511020051-3/83
937281-82 318AT Fed BV O2 (4179179)4096511023601-3/83
937381 318AT CA BV O2 (4179180)4096511023601-3/83
937482-83 318Fed HA BV O2 (4227251)4096511023821-3/83
937582 318 TruckFed CA Can BV (4241752)4098511020051-3/83
937682 360 TruckBV CA (4241753)4104511023261-3/83
937781 360 TruckBV HD Fed late (4213714)4098512523771-3/83
937983 360 TruckBV Fed Can (4287016)4098512523771-3/83
938082 360Mex4096512521591-3/83
938282 351Ford AU MT (80TA-BA)4101509523631-3/87
938382 351Ford AU AT (80TA-BB)4101509523631-3/87
9384Production Canceled(4286025)4098511023591-3/83
938582-83 318Fed BV O2 (4287051)4096511023601-3/83
938684 360 TruckFed BV Alc (4287064)4095511019981-3/83
938784 360 TruckBV (4287065)4097511020861-3/83
938883 318AT BV O24096511023601-3/83
938984 318AT BV O2 (4300012)4092511019651-3/83
9390Production Canceled------4097511019651-3/83
939184 318AT BV O2 HA (4300019)4093511021441-3/83
9800Super-QuadGM4095513721101-3/85
9801Super-QuadChrysler4095512521101-3/85
9810Super-QuadGM, EGR4095513723751-3/85
9811Super-QuadChrysler, EGR4097512523851-3/85
Pri. = Primary Jet
Exp = Export
AU = Australia
Mex = Mexico
MH = Motorhome
Numeric Listing​
To view my whole document, see A Carter Thermo-Quad Guide, Version 3.1.
For other versions and more information, see Vaanth Thermo-Quad Site.
I got a look at them today
I always liked the thermoquads
But my 69 is getting a stock build
So it was just a bonus to the 340 I bought
Not sure what im doing with it
Think its worth more if I tare it down clean it up make it run and sell it
Or sell the heads and short block separately
