abqphilbert
Active Member
I'm hoping somebody out there can make a recommendation on what size primary jets, metering rods, and secondary jets I should try (start with). I have a 9022 S Thermoquad that I want to rebuild for my 318 four-speed Dart. This carb was originally on a 1974 360 truck engine with automatic transmission. I haven't been able to find anyone local that knows much about these carbs, so I'm looking for somebody that knows more about these carbs than I've been able to learn from my own research so far.
I live at 5,500 ft. elevation, and have found the other carbs I've used had to be jetted a little leaner here than they would at or nearer to sea level. I'm guessing this carb is jetted too rich for my engine even if I was at sea level - but I don't really know that to be correct. I haven't rebuilt it yet or tried to run it as it's currently jetted. I figured I'd do a bit more research first, and hopefully same some time and work later.
This car is a daily driver. My engine is a 1973 stock displacement 318, original heads with 1.88 intake valves, standard-sized exhaust valves, ported & polished, 9.8 compression, solid-lifter COMP cam with .468 lift on both intake & exhaust, Doug's headers, Edelbrock Performer intake, and electronic ignition. The car has an A-833 overdrive and an 8.75 axle with 3.23 and sure-grip.
I understand that whatever jets I start with may turn out to be less-than-perfect, and may require more adjustment later, but I'd really like some input from anyone out there willing to offer it, so I can start with something that has worked well for somebody else.
Hope to hear from some other members.
Thanks .
Thanks .
