Thermostat Question
72Plymouth
Vista, CA
I am going through the cooling system right now. My Plymouth service manual says that the standard thermostat is 185 F but Napa and Autozone says that OEM calls for 195 F. They don't sell 185 so I got a 180 thermostat.
Any thoughts?
195 for California ;
185 for 49 state models .
these numbers are for the 1972 model year .
I run a 195 in my daily driver 1972 Coronet , stock 318 / 904 , 26" factory rad .
The trick is to not go too low temp-wise , otherwise your car can actually run hotter !
I think I actually ran mine for 5 or 6 years with no thermostat. It doesn't stay cold here for very long and the thought was then that no restriction = cooler engine temps. Never had any issues other than having no heat for the first 20 miles or so. Looking back now, I got so lucky so many times with that car. Any one of the stupid things I did could have ended in disaster. Better to be lucky than good.
180 will work fine. Anything below 195 will sure screw up a fuel infection system though.
