I did exactly this swap, and LOVE it. Would NOT change a thing.
Some tips?
As mentioned, get the Magnum flywheel, NOT the 360 'wheel. Now, if you were inclined to get the Mcleod flywheel, I just so happen to have in the classified section, a weight to balance ANY Mcleod flywheel to 5.9 specs, and it's priced right.
I recommend running the Magnum accessories.
I ran all the Magnum accessories on mine. I don't know 100% on early A's (Mine is a '72), but the serp belt, late alternator and simple brackets were a big win in my book. I run the B-van PS bracket (it sits lower), and you'll need the non-AC Magnum alt bracket if you run without AC, and I used a mid-90's PS pump housing from a Dakota (The filler is clocked inwards a little more) and it all fit without hitting my stock battery tray. Battery in the trunk? Then all the Ram brackets fit, AC or not, no problem. The old-school PS Pump body fits the later brackets.
Of course, that assumes you even HAVE power steering. One trip to a well-stocked salvage yard had everything I needed but the alternator bracket. I don't know why they ever made a different one for non-AC but they did, even though no factory truck ever seems to have been made that way. I called salvage yards in CANADA (Like, frozen north, no AC?), and there weren't any. The dealer has them, I can get you the number if needed.
The alternator is a direct connection too. Just run the output wire (Go big on it, the alternator is high-amperage) with the appropriate fusible link directly to the battery stud on starter relay.
I'd stay away from the Chinese air-gap, and get the real deal. I had a hellacious time getting the bypass hose and other oddball bits for the intake.
Do it, you won't regret it!
