But it's small block Ford and it's a subject that's been very popular. I got my 75 F250 back running again today after a camshaft and lifter failure. I ended up using Blueprint Engines 30SAE break in oil. I got the engine cleaned up from the failure, lubed the camshaft lobes with ZDDP paste and the journals with Ultra Slick. I coated the lifter bottoms with ZDDP paste and the sides with Ultra Slick. I also made some mods to help oil pressure, as these engines are known for problems in that area. That's why I put the truck down originally back in February. It lost oil pressure at idle. I got the engine running this afternoon. I primed it the day before, so oil pressure buried the 80PSI gauge as soon as it fired. I got the RPM up to the ~3000 RPM range varying it somewhat. I ended up having a bit over an hour run time on it. Cut it off and let it cool all the way back down then restarted it and gave it some RPM a little while longer. When I felt like it was enough, I finally let it idle. It was the same old lumpy Crane Fireball it was that I took out. Holds about 40 oil pressure hot and will bury the 80 mark at 2K. I went ahead and dropped the break in oil out tonight and removed the filter. There was ZERO metal in the oil and ZERO metal in the filter. I think maybe we got it. It runs good. There's no valve train noise whatsoever, and it doesn't skip or run rough. I do have some leaks at the collectors under the truck I need to fix and of course, the power steering pump decided to take a crud. But so far, it's lookin good. Anyway, here's Gladys back in all her lumpy glory. I hope for a long time now.
