Not sure, but I would guess this is something that is not legal.
http://seattle.craigslist.org/see/cto/2869551763.html
I am glad they make the reproduction rivets. The fab guy removed the vin tag off of my dash. Never did find out why, although if I remember right where he cut the dash to get the cage thru it is pretty close to the tag. Former neighbor purchased a real 69 Z28 that had been turned into a track car. He cut the numbers off of the car & attempted to sell the car and the tags separate. Last I had heard from him he had no luck selling either the tags nor the car, car was pretty much a turd.i run into those adds from time to time. i just cant see how any of that can be legal. i dont believe tampering with dash VIN number tags is legal. but... you can buy reproduction rivets. trying to misrepresent a car with those tags and numbers is illegal unless it is disclosed to the buyer. and, there are numbers stamped onto the body , so it could be confirmed if the car is actually the body born with the VIN number, unless you cut those pieces out and weld them into the new body, which a lot of people do.
I'm not sure if the sale or purchase of these items is really violating any law. It's what you DO with them that can be extremely illegal. Obviously the seller has that intent in mind, but the tags and build sheet are just car parts.
I obviously think this is bad, and should not be allowed. But it may not be exactly "illegal" per-se.
I believe that law states removing numbers from a vehicle is illegal
that's the whole point right there-you can make any car 'your car' by putting 'your' VIN on it, regardless of how you came to obtain it.Its my car
Hmmm, is it removal or replacement.
Its my car, on my property, I should be able to do anything I like with it--so long as it stays on my land and harms nobody
Even if there is a law, it might not hold up in court--if you want to spend the $$$$ to fight it
Also how can the state prove it was removed in their state ?
Like I said, the seller better be a good talker--or not talk at all
