First, Thanks to all.
I think Jonny Dart and others are correct with operator error
The original question was if I used a good product.
Seems like I used a good product, I think my prep was mainly correct. I just did not follow the instruction by filling the coolant right away. My wife was putting thread sealer on the bolts and handing them to me when I was assembling. She pointed out that the leaking bolt was the first one we installed. It also was the first sealant out of the tube. Neither of us can remember if the sealant was any different for the first bolt. There were no problem with any of the other bolts. So separation in that first bit maybe??
What I left out in my prep was that I used all new bolts and cleaned them with brake cleaner (just what was in reach). I did clean all of the threads in the block with a tap per my original post so I think I had good clean thread surfaces. I also tightened with a torque wrench.
The problem bolt was driver side 2nd up from bottom that also holds the power steering bracket.
I was going to reinstall last night but work got in the way (man I need to win the lottery).
The plan for tonight is to knead the tube good, put plenty on the bolt and let it sit overnight before I do anything. I went back and read the tech sheet. It looks like you have a good seal after 4 hrs and a full pressure seal (10,000 psi) after 24 hrs.
I am sure this will solve the problem.
Thanks again
