I recently changed my timing chain and now have a leak out of a bolt in the timing chain cover.
Before installing the cover I ran a tap through all the holes in the block.
I used high temperature thread sealant on all bolts.
I did not remember which bolts went into the water jacket so I did them all.
At first I thought that I had brain fade while assembling and forgot to seal the bolt that was leaking. I drained the coolant last night and pulled the bolt. It did have sealant on it?
Attached is a picture of the thread sealer I used.
Did I use the wrong stuff? Maybe a bad tube?
What do you use?
Thanks
What do you use?
Thanks
