Throttle bracket
Small Block Mopar Engine
  1. moparmucelli
    moparmucelli Well-Known Member
    192
    10
    Sep 15, 2013
    murrieta ca
    Local Time:
    1:28 PM
    hi guys I’m going to be converting my 360 2 barrel to a 4 barrel and I’m wondering if I can keep the throttle bracket that’s on it now or do I have to get a different bracket?
  2. moparmucelli
    192
    10
    Sep 15, 2013
    murrieta ca
    Local Time:
    1:28 PM
    Also is there anything else I have to change to do the swap?
  3. pntastar69
    pntastar69 Well-Known Member
    1,394
    75
    Dec 28, 2006
    Gilbertsville, PA
    Local Time:
    6:28 PM
    What intake are you using?
  4. moparmucelli
    192
    10
    Sep 15, 2013
    murrieta ca
    Local Time:
    1:28 PM
    Edelbrock performer 318/360
  5. SSG_Karg
    SSG_Karg Dismembered
    807
    424
    Feb 24, 2010
    In the pits
    Local Time:
    4:28 PM
  6. moparmucelli
    192
    10
    Sep 15, 2013
    murrieta ca
    Local Time:
    1:28 PM
  7. SSG_Karg
    807
    424
    Feb 24, 2010
    In the pits
    Local Time:
    4:28 PM
    I use it on an Edelbrock Torker 340 with a Holley 650 DP carb. Only thing I had to do was use 2 slightly longer carb studs on the cable side as the bracket mounts on them. Otherwise it fits perfectly and looks very clean.
  8. SSG_Karg
    807
    424
    Feb 24, 2010
    In the pits
    Local Time:
    4:28 PM
    Installed
    • Like Like x 1
    • Phil21502
      Phil21502 Well-Known Member
      101
      18
      Jul 27, 2018
      Maryland
      Local Time:
      4:28 PM
      With that bracket how do u use a kickdown rod?
      • Like Like x 1
      • SSG_Karg
        807
        424
        Feb 24, 2010
        In the pits
        Local Time:
        4:28 PM
        Can’t say. I don’t run one. Does not appear to have a provision for one.
      • mopowers
        mopowers Well-Known Member
        3,823
        999
        Feb 15, 2006
        West Sacramento, CA
        Local Time:
        1:28 PM
        If you can weld, you can easily raise the height of the bracket and lengthen the kickdown rod.
        • Agree Agree x 1
        • pntastar69
          1,394
          75
          Dec 28, 2006
          Gilbertsville, PA
          Local Time:
          6:28 PM
        • doogievlg
          doogievlg Well-Known Member
          6,868
          1912
          Nov 13, 2007
          Amelia, Ohio
          Local Time:
          4:28 PM
        • Peter Bates
          Peter Bates 1973 Cuda owner for 36yrs
          137
          107
          Aug 25, 2018
          Sylvania ohio
          Local Time:
          4:28 PM
          I have a stock set up that you can have. I have it posted on the Forum for another person but I am not privy to who gets it. First come first serve and i just wanna help. Peter 7345453794. I'll send it free.
        • teringer
          teringer ase master hall of fame
          720
          118
          Feb 22, 2011
          kenly nc
          Local Time:
          3:28 PM
          well I use spacers under the 2 new longer bolts I install, then bend the bracket to aline it .
