69Chrgr
Charger/Cuda
I just disassembled my 408 and found the thrust bearing heavily worn. My thrust bearing surface on my Eagle crank is fried as well as the bearing. I had no problem with the flexplate or converter fitting in the hub of the crank when I built the engine 2 years ago. Although you can see where the hub of the converter has bottomed out in the cranksaft female end. Any ideas? I'm afraid my crank is fried. Can it be machined and run an oversize thrust bearing, or do I have to bite the bullet and get a new crank. This is getting depressing.:angry7:
