if you can remove the spacer,do it.The less parts moving around in the carrier the better.The spacer is used to put tension on the left axle,when the right axle is installed and adjusted,it pushes against the spacer,pushing against the left axle.Since the moser axle and green bearing do not need this adjustment,there is no need for the spacer.mrmopartech
